I am attempting to replicate a code I found in a youtube video, the only difference being is that I am using a tracker SoM (T402) Evaluation KIT. The error code I am receiving is “error code 500”. Can anyone tell me what I am doing incorrectly?
#include <google-maps-device-locator.h>
#include <TinyGPS++.h>
static const uint32_t GPSBaud = 9600;
static const int blue_led = D7;
static const double movingDelta = 0.0001;
int stationaryDelay = 30 * 60 * 1000;
int movingDelay = 60 * 1000;
// Init GPS library
TinyGPSPlus gps;
TinyGPSCustom antennaStatus(gps, "PGTOP", 2);
// Init cell location library
GoogleMapsDeviceLocator locator;
// Tracking where we last were
double lastLat = 0;
double lastLng = 0;
float lastSend = 0 - movingDelay;
// Start debugging serial
Serial.begin(115200);
Serial.println("Booting");
// Start GPS serial
Serial1.begin(9600);
Serial1.println("$PGCMD,33,1*6C");
// On-demand location
Particle.function("locateCell", locateCell);
Particle.function("locateGps", locateGps);
Particle.function("setMovingDelay", setMovingDelay);
Particle.variable("movingDelay", movingDelay);
// Setup debugging LED
pinMode(blue_led, OUTPUT);
// Debug with satellite info always
Serial.print("Satellites: ");
Serial.print(gps.satellites.value());
Serial.print(" Antenna: ");
Serial.print(antennaStatus.value());
Serial.print(" Chars: ");
Serial.print(gps.charsProcessed());
Serial.print(" Failed: ");
Serial.println(gps.failedChecksum());
// See if we need to send
bool needsSend = false;
double latDiff = lastLat - gps.location.lat();
double lngDiff = lastLng - gps.location.lng();
latDiff = abs(latDiff);
lngDiff = abs(lngDiff);
float sentAge = millis() - lastSend;
if (sentAge < 0) lastSend = 0;
if (sentAge > stationaryDelay) {
needsSend = true;
Serial.print("Sending due to stationary delay ");
Serial.println(sentAge);
if (sentAge > movingDelay && gps.location.isValid()) {
if ((latDiff + lngDiff) > movingDelta) {
needsSend = true;
Serial.print("Sending due to movement ");
if (gps.speed.knots() > 10) {
needsSend = true;
Serial.print("Sending due to speed ");
if (needsSend) {
sendLocation();
// Check good GPS wiring
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
smartDelay(5000);
locator.loop();
// Sends the current location
void sendLocation() {
// Send GPS location if valid
if (gps.location.isValid()) {
digitalWrite(blue_led, HIGH);
String data = String::format(
"{ \"lat\": %.6f, \"lng\": %.6f, \"alt\": %.0f, \"hdop\": %li, \"time\": \"%04u-%02u-%02uT%02u:%02u:%02uZ\", \"spd\": %lf, \"crs\": %lf, \"sat\": %lu }",
gps.location.lat(),
gps.location.lng(),
gps.altitude.meters(),
gps.hdop.value(),
gps.date.year(),
gps.date.month(),
gps.date.day(),
gps.time.hour(),
gps.time.minute(),
gps.time.second(),
gps.speed.knots(),
gps.course.deg(),
Particle.publish("sendlocation", data, PRIVATE);
Serial.print("Sent location lat: ");
Serial.print(gps.location.lat(), 6);
Serial.print(" long: ");
Serial.println(gps.location.lng(), 6);
digitalWrite(blue_led, LOW);
// Store what we sent to see when we need to next
lastSend = millis();
lastLat = gps.location.lat();
lastLng = gps.location.lng();
} else {
"{ \"time\": \"%04u-%02u-%02uT%02u:%02u:%02uZ\", \"sat\": %i }",
gps.date.year(),
gps.date.month(),
gps.date.day(),
gps.time.hour(),
gps.time.minute(),
gps.time.second(),
Serial.println("Sent invalid location");
// This custom version of delay() ensures that the gps object is being "fed".
static void smartDelay(unsigned long ms) {
unsigned long start = millis();
do {
while (Serial1.available()) {
byte c = Serial1.read();
gps.encode(c);
//Serial.print(char(c));
} while (millis() - start < ms);
// On-demand cell location
int locateCell(String extra) {
locator.publishLocation();
return 0;
// On-demand GPS location
int locateGps(String extra) {
sendLocation();
return 0;
// Dynamic setting of move delay
int setMovingDelay(String extra) {
movingDelay = extra.toInt();
return 0;
