Help with displaying data in Ubidots
I am working on a project to show how many hours the machine was ON, I am using particle electron with vibration sensor. i was able to send the minutes and hours reading in ubidots but i send them as two variables, how can i send the minutes and hours and one reading with this format (MIN:HOURS).
If you used a common format where hours go before minutes you’d be probably better off :wink:
Why not just use a plain old timestamp?
Time.now()
sorry i mean Hours:Min, how i can send them as one variable to ubidots.
many thanks,
i need the number of hours that a machine was on, it is like a counter, which stops when the machine stops.
thanks
@Metavix works with Ubidots, he may be able to help out.
@msavooo, why don’t you convert HH:MM to just minutes. That way it is a single, non-fractional number :wink:
@msavooo The best solution is to use a format with minutes and in Ubidots cloud platform you should use a derivated variable. You also be able to use a context in a variable to give more data of a variable as minutes, seconds, hours or whatever.
That is my suggestion!
Best Metavix
