I am new to Arduino, how can I use I2C to make a slave Arduino to perform calculations in parallel. The slave Arduino acts as a device with hardware registers (like the Accelerometer).
Hi @Fylinde
First, welcome to the PARTICLE Forum
Second, I believe this is not the correct forum to ask about Arduino related matters. Having said that, I believe this link will be able to assist you
Arduino I2C connection
Example 2
Example 3
Now, if you want to know anything about Particle products, this is the place to be and we will gladly assist. Hope to see you back here again un future building some amazing things using Particle
Good luck and keep innovating
Regards, Friedl.
Hi Friedi. Thanks for the tip
