Here’s a little challenge for the folks much more fluent in C than I am (which is mostly everyone). I have a Core connected to my 3D printer RAMPS board running Marlin. It can successfully issue commands over serial and retrieve the response. The one G-code command that I’m interesting is parsing is M105 to get all of the temperatures. That command returns a string like ok T:21.9 /0.0 B:22.1 /0.0 T0:21.9 /0.0 @:0 B@:0 ok T:22.0 /0
. I’d like to extract the first 4 numbers (21.9, 0.0, 22.1, and 0.0). I have it working with a series of terrible String .substring()
and .indexOf()
functions, but it’s ugly.
Here’s what that mess looks like:
void getTemperatures() {
if(String strTemps = sendData("M105")) {
// ok T:21.9 /0.0 B:22.1 /0.0 T0:21.9 /0.0 @:0 B@:0 ok T:22.0 /0
// Get extruder current temperature
String a = strTemps.substring(strTemps.indexOf("T:")+2, strTemps.indexOf("/"));
a.trim();
//Spark.publish("wi3d", a);
// Get extruder target temperature
String b = strTemps.substring(strTemps.indexOf("/")+1, strTemps.indexOf("B:"));
b.trim();
//Spark.publish("wi3d", b);
// Get bed current temperature
String c = strTemps.substring(strTemps.indexOf("B:")+2, strTemps.indexOf("/", strTemps.indexOf("B:")+2));;
c.trim();
//Spark.publish("wi3d", c);
// Get bed target temperature
String d = strTemps.substring(strTemps.indexOf("/", strTemps.indexOf("B:"))+1, strTemps.indexOf("T0:"));
d.trim();
Spark.publish("wi3d", d);
It returns the values I'm looking for, but it feels like there should be a better/easier way of doing it. I know regular expressions aren't available, but maybe it could be done with `sscanf()` or another method. Since there are (literally) hundreds of G-code commands, a regex or sscanf-like parsing method would be preferred.
Any ideas?
