Hello,
We used the mobile app to configure the photon, and we were able to light up the onboard LED.
We are now attempting to use node-red to light up the LED.
I see the device id. Also, in the my_device -> view devices… -> see in termional
I can see a token. Eg:
curl https://api.particle.io/v1/devices/events?access_token=…
I guess that would be the access token I use?
There just doesn’t seem to be an obvious “here is what you should use to connect to your photon”.
Is there a way I can see my local network url? (I can see via the web app what my home router IP is).
How do I determine the values to connect other apps directly to the photon? Even if just to call the functions like digitalwrite (D7,HIGH)…
Thank you,
Bossman
