Health Check - Problem?
Hi, is there any way to check what’s causing the problem? It’s been like that for a couple of months on my two Boron LTE devices. Firmware update or reset doesn’t really change anything. Please advise, thank you.
The warning is for the box on the right “This device may be experiencing lower-than-optimal cellular signal.” If it’s working, it’s nothing to worry about, however if you’re experiencing communications difficulties, then investigate positioning, antennas, etc…
