I have a Base class for relays and have been looking at creating children classes for the types of things that would be controlled by the Relays. At this time I can’t think of any implementation code differences between the Base and Child and at this time the main difference between Base and Children are the enums that provide a descriptive state of what happens when the relay is open or closed. Given that info and the code below…am I on the correct path here?
NOTE: I am fairly certain I don’t have my virtuals done properly…would it be just the Base class that has functions defined as Virtual (I think pure virtuals is the answer) and nothing for the children? Is there a way to have the Base class return Child enum types for further use in other parts of my app?
Base Class
typedef enum {
RELAY_STATUS_OPEN = 0,
RELAY_STATUS_CLOSED = 1
} relay_status_t;
class Pacsui_Relay
private:
//Private functions
//Private variables
public:
//Public functions
Pacsui_Relay(void);
virtual void begin(int pin);
virtual relay_status_t on();
virtual relay_status_t off();
virtual relay_status_t getState();
//Public variables
relay_status_t relayStatus;
protected:
int _pin;
#endif
Child
typedef enum heater_status_t {
HEATER_STATUS_OFF = 0,
HEATER_STATUS_ON = 1
} heater_status_t;
class Pacsui_Heater : public Pacsui_Relay
private:
//Private functions
//Private variables
//Class Objects
public:
//Public functions
Pacsui_Heater(void);
virtual ~Pacsui_Heater();
virtual void begin();
virtual heater_status_t on();
virtual heater_status_t off();
//Public variables
extern Pacsui_Heater heater;
#endif
