Noten
February 5, 2014, 10:02pm
1
Dear All!
I’m trying to power the spark from a raspberry pi (thru a pi cobbler). I just connected the 5v0 (from the cobbler) and VIN ports (on the spark), but the spark is not booting.
You can find more info about the cobbler here: http://learn.adafruit.com/adafruit-pi-cobbler-kit/overview
Am i missing something? Thanks for your help!
weakset
February 5, 2014, 10:15pm
2
Did you remember to connect ground also? I have missed that more than once…
Noten
February 5, 2014, 10:24pm
3
Hi @weakset !
Yes, it’s also connected (maybe i’m not doing it properly), find attached the image how i did it.
(it’s connected like VIN -> 5v0, GND -> GND)
Any idea why it’s not switching on? The pi is getting enough power on usb, coz it’s connected to an usb charger.
thx,
Noten
Raldus
February 5, 2014, 10:31pm
4
You have the ribbon cable connected upside down, like the instructions warn you not to do???
(Get a voltmeter and check the voltages. Also, make sure that your USB connection or whatever at the pi end can supply enough power for both.)
Noten
February 5, 2014, 10:34pm
5
@Raldus that was it!!! Thank you very much for your help guys!
it started to work;)
