Does anybody know if that code is solid / stable and works ?
I finally did get it to compile, but when i flash it to my cube it doesn’t run.
I see the blue led blinking rapidly when it says its loading, but it doesn’t do anything after that.
I also tried the *.bin files they have there, and loaded via the CLI, same problem.
My cube has been working perfectly oh these past years, and i just thought I would try the PROCESSING application, and loaded the Listener, but never could get that to work.
If i had known cubetube.org was gone, i might not have played with it.
I used cubettube and tried all the code loaded there, throughout the years, and never had a problem.
Any help would be greatly appreciated.
