I’ve tried to find some help on this, but have failed miserably. I’m not an experienced Java coder, so any help is appreciated. Apologies for the untidiness of my code.
I’ve written some Java code which works on my Android phone to control and display the status of my home central heating system. So far so good. However, when the READ STATUS button is pressed, I’d like to have a progressbar displayed. The series of 8 calls to the Particle takes up to 10 seconds to complete, then the entire display updates - it would be awfully nice to achieve incremental updates as the data is received. Sorry the code is so vast - I’d like to use more nested code but haven’t figured out how yet. The Particle is running a modified version of Tinker.
package net.gotopcs.www.heatingcontroller;
import android.app.ProgressDialog;
import android.os.AsyncTask;
import android.os.StrictMode;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.support.v7.app.AppCompatActivity;
import android.util.Log;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.widget.Button;
import android.widget.ProgressBar;
import android.widget.RelativeLayout;
import android.widget.TextView;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.HttpClient;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.impl.client.DefaultHttpClient;
import org.apache.http.message.BasicNameValuePair;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.util.ArrayList;
import java.util.List;
import static android.provider.SyncStateContract.Helpers.update;
public class ControlHeating extends AppCompatActivity {
private ProgressBar firstBar = null;
private int i = 0;
RelativeLayout layout;
TextView ATextView;
TextView BTextView;
TextView CTextView;
TextView DTextView;
TextView FTextView;
TextView GTextView;
TextView HTextView;
String longstring;
String shortstring;
String TAG = "dgc";
Button Abutton;
Button Bbutton;
Button Cbutton;
TextView CHradio;
TextView HWradio;
BufferedReader in = null;
String access_code = "my access code";
String analogread = "https://api.particle.io/v1/devices/my device/analogread";
String digitalwrite = "https://api.particle.io/v1/devices/my device/digitalwrite";
String HeatFunction;
String DigNumber;
int foo;
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_control_heating);
StrictMode.ThreadPolicy policy = new StrictMode.
ThreadPolicy.Builder().permitAll().build();
StrictMode.setThreadPolicy(policy);
firstBar = (ProgressBar)findViewById(R.id.firstBar);
CHradio = (TextView) findViewById(R.id.radioButton1);
CHradio.setText(" ---- ");
HWradio = (TextView) findViewById(R.id.radioButton2);
HWradio.setText(" ---- ");
ATextView = (TextView) findViewById(R.id.editText5);
ATextView.setText(" - - - - ");
BTextView = (TextView) findViewById(R.id.editText6);
BTextView.setText(" - - - - ");
CTextView = (TextView) findViewById(R.id.textView);
CTextView.setText(" - - - - ");
DTextView = (TextView) findViewById(R.id.textView8);
DTextView.setText(" - - - - ");
GTextView = (TextView) findViewById(R.id.textView28);
GTextView.setText(" - - - - ");
HTextView = (TextView) findViewById(R.id.textView38);
HTextView.setText(" - - - - ");
FTextView = (TextView) findViewById(R.id.editText29);
Cbutton = (Button) findViewById(R.id.button3);
/* layout.setVisibility(View.VISIBLE);
firstBar.setVisibility(View.VISIBLE);
firstBar.setMax(150);
//Set first progress bar value
i = 10;
firstBar.setProgress(i);
RefreshStatus("CH");
i = 50;
RefreshStatus("HW");
i = 100;
RefreshStatus("Pump");
i = 150;
firstBar.setVisibility(View.GONE);
Cbutton.setOnClickListener(new View.OnClickListener() {
@Override
//On click function
public void onClick(View view) { // code run when "Read Status" button clicked
/*Create whatever the button does
//make the progress bar visible
i = 10;
//Create an object of HttpClient
HttpClient httpclient = new DefaultHttpClient();
//Create an object of Httppost
HttpPost httppost = new HttpPost(analogread);
// Extract reading for top temperature
try {
// Add your data
List<NameValuePair> nameValuePairs = new ArrayList<NameValuePair>();
nameValuePairs.add(new BasicNameValuePair("access_token", access_code));
nameValuePairs.add(new BasicNameValuePair("String pin", "A0"));
httppost.setEntity(new UrlEncodedFormEntity(nameValuePairs));
// Execute HTTP Post Request
HttpResponse response = httpclient.execute(httppost);
in = new BufferedReader(new InputStreamReader(response.getEntity().getContent()));
} catch (ClientProtocolException e) {
// TODO Auto-generated catch block
FTextView.setText("Error 001");
} catch (IOException e) {
FTextView.setText("Error 002");
// response collected in buffer and print in logcat
String s = null;
longstring = "";
try {
Log.d(TAG, "Top temp");
while ((s = in.readLine()) != null) {
Log.d(TAG, s);
// build up a string of s's here
longstring = longstring + s;
ss(longstring, 90);
ATextView.setText(shortstring.substring(1, 3) + "." + shortstring.substring(3, 4) + " °C");
e.printStackTrace();
//i = 40;
//AsyncTask(i,stuff,things);
//firstBar.setProgress(i);
//Create an object of Httppost for bottom temperature
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("String pin", "A1"));
FTextView.setText("Error 003");
FTextView.setText("Error 004");
String t = null;
longstring = "";
try {
Log.d(TAG, "Bottom temp");
while ((t = in.readLine()) != null) {
Log.d(TAG, t);
longstring = longstring + t;
ss(longstring, 90);
BTextView.setText(shortstring.substring(1, 3) + "." + shortstring.substring(3, 4) + " °C");
//i = 80;
//Create an object of Httppost for Supply voltage
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("String pin", "A2"));
FTextView.setText("Error 005");
FTextView.setText("Error 006");
String u = null;
longstring = "";
try {
Log.d(TAG, "Supply volts");
while ((u = in.readLine()) != null) {
Log.d(TAG, u);
longstring = longstring + u;
ss(longstring, 90);
CTextView.setText(shortstring.substring(1, 3) + "." + shortstring.substring(3, 5) + " V");
//i = 120;
//Create an object of Httppost for external temperature
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("String pin", "A5"));
String v = null;
longstring = "";
try {
Log.d(TAG, "External temperature");
while ((v = in.readLine()) != null) {
Log.d(TAG, v);
longstring = longstring + v;
ss(longstring, 90);
GTextView.setText(shortstring.substring(1, 3) + "." + shortstring.substring(3, 4) + " °C");
//i = 130;
//Create an object of Httppost for spare indicator
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("String pin", "X1"));
FTextView.setText("Error 025");
FTextView.setText("Error 026");
String w = null;
longstring = "";
try {
Log.d(TAG, " t3 ");
while ((w = in.readLine()) != null) {
Log.d(TAG, w);
longstring = longstring + w;
ss(longstring, 90);
HTextView.setText(shortstring.substring(1, 3) + "." + shortstring.substring(3, 4) + " °C");
//Create an object of Httppost for CH status etc
//i = 150;
//firstBar.setVisibility(View.GONE);
}// end of onClick stuff
}); // end of Cbutton stuff
Abutton = (Button) findViewById(R.id.button);
Abutton.setOnClickListener(new View.OnClickListener() {
@Override
//On click function
public void onClick(View view) { // code run when "Toggle CH" button clicked
HttpPost httppost = new HttpPost(digitalwrite);
// toggle CH status button command
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("D0,HIGH", "D0,HIGH"));
FTextView.setText("Error 007");
FTextView.setText("Error 008");
String x = null;
longstring = "";
HeatFunction = "CH";
try {
Log.d(TAG, "toggle CH");
while ((x = in.readLine()) != null) {
Log.d(TAG, x);
longstring = longstring + x;
ss(longstring, 89);
RefreshStatus(HeatFunction);
}); // end of CH toggle button stuff
Bbutton = (Button) findViewById(R.id.button2);
Bbutton.setOnClickListener(new View.OnClickListener() {
@Override
//On click function
public void onClick(View view) { // code run when "Toggle HW" button clicked
//progress = ProgressDialog.show(this, "Reading Status", "One moment please", true);
//progress.dismiss();
// toggle HW status button command
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("D1,HIGH", "D1,HIGH"));
FTextView.setText("Error 009");
FTextView.setText("Error 010");
String y = null;
longstring = "";
HeatFunction = "HW";
try {
Log.d(TAG, "toggle HW");
while ((y = in.readLine()) != null) {
Log.d(TAG, y);
longstring = longstring + y;
ss(longstring, 89);
//DTextView.setText(shortstring);
// end http post stuff
}); // end of HW toggle button stuff
@Override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.menu_control_heating, menu);
return true;
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
//noinspection SimplifiableIfStatement
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
public String ss(String ls, int cutoff) {
// stuff
shortstring = ls.substring(cutoff); // remove lead 89 chars
return shortstring;
public void RefreshStatus(String HeatFunction) {
// subroutine to check heating function after toggle button is pressed
if (HeatFunction == "CH") { DigNumber = "D2"; }
if (HeatFunction == "HW") { DigNumber = "D3"; }
if (HeatFunction == "Pump") { DigNumber = "D4"; }
try {
// Add your data
nameValuePairs.add(new BasicNameValuePair("String pin", DigNumber));
FTextView.setText("Error 011");
FTextView.setText("Error 012");
String v = null;
longstring = "";
try {
Log.d(TAG, HeatFunction + "status");
Log.d(TAG, v);
shortstring = longstring.substring(91, 92); // remove lead 91 chars
foo = Integer.parseInt(shortstring);
if (foo > 0) {
CHradio.setText(" " + HeatFunction + " OFF");
} else {
CHradio.setText(" " + HeatFunction + " ON");
if (foo > 0) {
HWradio.setText(" " + HeatFunction + " OFF");
} else {
HWradio.setText(" " + HeatFunction + " ON");
if (foo > 0) {
DTextView.setText(HeatFunction + " is ON");
} else {
DTextView.setText(HeatFunction + " is OFF");
