Hi, tried searching the forum but couldn’t find much about this.
I’ve used the Core for a while but am having issues with the Photon. I’ve wired up an RFID to it ( the MFRC522 ) and connected it as advised. Have connected it to the net successfully and flashed it with the following:
#include "MFRC522/MFRC522.h"
#define SS_PIN A2
#define RST_PIN D2
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
String cardID = "";
for (byte i = 0; i < mfrc522.uid.size; i++)
cardID += String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
cardID += String(mfrc522.uid.uidByte[i], HEX);
Serial.println(cardID);
Particle.publish("pushover", cardID + " scanned");
mfrc522.PICC_HaltA();
The result connects to the net and breathes cyan for a couple of breaths… then breathes nothing but green.
How come it can;t connect to the cloud? it’s going via my phone which has internet, and AFAIK my network cant tell I’m tethering to restrict it (giffgaff - android, worked fine with the photon to flash it). Any help would be much appreciated! I can reflash it but it seems to be the above code causing this, never used an external Lib before on Photon, anyone have any tips?
