Get data from a URL
Hi, i need to send a request to an url (ex http://192.168.0.2/rest/) and get a value through this request? How can I do it?
Ludovico.
Have you seen the HTTP library?
Can you post a code example?
Thank you.
Go to Particle build, select Libraries, and then select the HTTP Client library for an example :slight_smile:
Ah ok, thank you!
