As far as I can tell, the cloud compile feature uses GCC 5 under the hood. This compiler version is four years old and does not support C++14 onwards (only C++11).
Are there any plans to upgrade to a newer GCC? The current version is 9.2. The device-os seems to be compatible with a newer GCC.
