What exactly do you define as wrong? Could you post some output from your program and describe what readings you believe are erroneous?
Also, from the PLX_DAQ website… are you aware the software is no longer supported? Have you tried PLX_DAQ with any other micro-controller successfully? It looks like Parallax developed the software for use only with their controllers. I’m not sure what is proprietary about it so do you know if it will work with Particle devices?
