I’m not sure why, but I felt like writing a little IRC bot. It has been AT LEAST 14 years since I last logged in to IRC and/or wrote an IRC bot. This is not some fancy eggbot, though. Heck, eggbot is now something that uses an Arduino to scribble on actual chicken eggs with markers these days!
I wanted to put this in front of you guys while I keep working on making it easier to use and expanding its list of commands to support Wikipedia’s list of internet relay chat commands. I’m probably going to need to write a command parse/function router to make it all-inclusive.
Right now, it can:
Log in
Set the nick
Continually increment a trailing integer if the nick is taken
Join a channel
Chat in a channel
Respond to IRC pings
Leave a channel
Quit the service
I’d like to add a “trigger” ability to be able to specify strings to listen for in a channel and respond appropriately. Adding them dynamically with Spark.function() might be rough given the 64-character max length, but longer triggers could be added in user code.
Right now, not a whole lot. It can do some very basics, but that’s about it. Next step will be to implement the list of IRC commands. After that, I’ll try to figure out a good way to do the triggers.
The original idea came as I logged onto IRC for the first time this millennium and wanted to possibly help support the folks there. I can only use the webchat at work, and I’m a web developer, so the IRC tab got hidden quickly! I was thinking it would be cool to flash an LED whenever there was channel activity. Unfortunately, port 6667 is blocked at work, so I can’t really rely on my idea to work there. I still thought it might be helpful for @zachary and all the others who idle on IRC throughout the day.
I finally figured out how to get discourse to flag every single post I haven’t read yet, can’t believe I hadn’t seen this one, this is sweet!
We talked about having a chat bot that sat around and would turn lights on/off for us, or flash when people are chatting in the channel and I’m not around.
