Trying to debug …Did a compiile for debug application (local)…then Start Debugging…only to now rcv the following error?
What do you get when you hit the button called Show Errors.
That would be more interesting than the non-informative message box
Before hitting the button:
After hitting the button:
It literally shows no errors…The 2 problems had to do with a lbrary not being linked and I went ahead and installed the library so it isnt that
