Firmware example for TPL5010 in docs
I'm looking at the code example Firmware - TPL5010 in the docs:
Isn't lastWatchdogMillis being reset to 0 each time the serviceWatchdog function is called? How can it compare the current millis() with the previous kick time?
No, it isn't. Because the variable is declared static, its value is not initialzed when it reenters scope.
It's essentially a global variable, but cannot be accessed outside that function.
I see thanks
