Is the bootloader actually a bootloader updater application? I can just flash this using YMODEM, right?
Otherwise, is there a DFU-UTIL command, because I’m not seeing it?
EDIT: It would be exceptionally helpful if someone has a tip on how to use dfu-util to flash the bootloader. This would mean I could do four consecutive dfu-util commands that loads part1, part2, bootloader, and application all in one go!
You’re right, the bootloader being an old version is apparently enough to prevent firmware from running… since I need it to run on the test stand, I MUST update the system firmware and the bootloader before it will run.
I just did an update with
particle flash --serial bootloader-0.7.0-p1.bin
…which after having intractable installation problems with particle-cli/npm, unexpectedly worked!
I can't find this information anywhere. I'm trying to avoid the particle command line tools because I have found them to be very flaky and somewhat unpredictable to install and use, especially since I'm integrating them into a larger script.
$ particle flash --usb -v temp-photon.bin
dfu-util 0.9
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 011a
Device returned transfer size 4096
DfuSe interface name: "Internal Flash "
Downloading to address = 0x080a0000, size = 3252
Download [=========================] 100% 3252 bytes
Download done.
File downloaded successfully
Flash success
You may update to 0.7.0 directly, but make sure you have installed v1.29.0 of the CLI (check with particle --version) then run particle update.
Note: P1/Photon Bootloader
The cloud will automatically update the bootloader on P1/Photon devices. If your device does not connect to the cloud, you should flash the bootloader to the device using particle flash --serial. This should be done after upgrading system firmware.
Edited:
Somewhat as expected, it wrote to 0x080a0000, so no different than an application.
It ended up continuously fast flashing white. I recovered it by writing my test firmware back over the address at 0x080a0000.
I think that bootloader-0.7.0-p1.bin is a "bootloader updater application" that has a magic component.. or I think the serial handler does something special with it....
Nope, the bootloader is running DFU Mode, so with the device in DFU Mode you can't replace the bootloader, but --serial is using YModem and this way you can replace the bootloader.
You have probably figured this out by now but the bootloader cannot be flashed via DFU and must be flashed via YModem or OTA for Photon and P1 with particle flash --serial bootloader.bin and only after you flash system parts.
