Hi there, I’m not sure if this is the correct place to report potential issues with Device OS versions, but here goes…
I’ve been running a Photon application for the last several months that makes use of the Thingspeak platform for data ingestion/logging/graphing. I believe this platform uses the MQTT format for data transfer. In any case, this application ran flawlessly while I was using Device OS 1.0.0, however, as soon as I upgraded to 1.1.0, the data transfer from my Photon to Thingspeak would stop from time to time, only restarting after I reset the Photon. I can confirm that the Photon was connected to the cloud the entire time.
Has anyone else experienced this? I just downgraded the OS back to 1.0.0 and I will monitor it closely.
Thanks.
