Feature request: servo PWM output in particle app
The android particle app is pretty cool, but when I select the A5 pin, I can choose “analogue output” - which probably works fine for dimming an LED: it would be awesome if another output mode was added into the app “servo output” so we can drive servos with this stock app :slight_smile:
There is an app called blynk, which is perfect for this and customizable
Ping @ido
Thanks for the suggestion. This feature is in our mobile backlog. It will be available at some point in the future.
