I have implemented a distributed set of sensors all communicating with publishing / subscribing to event names with a consistent namespace in the event names. Basically they look like sensor/temperature/request. Both the publish and subscribe events work swimmingly, but now that I’m developing a JS front-end I’m seeing 404 errors when trying to get the web browser to subscribe to the event names as they are above.
When I do onEvent for ‘sensor’ and ‘sensor/’ it works but when I add ‘sensor/temperature’ it with the 404 error. Is there any workaround for this?
@Moors7 thanks for the reply. While I could do that, I’d prefer to not have to process every event, just the ones that match the event path I specify. I’m just hoping there is some way to do this.
I wouldn’t know of a way to do that off the top of my head. Personally I’d go with the method I described above, since that requires only one listener. You can use if/else or switch/case statements to filter out the events you’re interested in. I don’t think that it would hurt too bad, performance-wise.
For alternatives, I’m going to refer you to the likes of @bko who undoubtedly knows more about these things than I do.
in this handler, similarly I’m only interested in the first response from my gmail webhook, it always has my gmail unread count. If there is dozens of returns, I only care to handle the one with the /0 added to the response:
void webhookHandler(const char *event, const char *data)
DEBUG_PRINTLN("Responding to webhook...");
DEBUG_PRINTLN(event); // just for debugging to see how the webhook was actually called
DEBUG_PRINT("Webhook is ");
DEBUG_PRINT(strlen(data)); // debug payload length
DEBUG_PRINT(" bytes and contains: ");
DEBUG_PRINTLN(data);
if (strstr(event, "my_gmail/0")) //<<<<<<<<<<<<<<<<<<<<<<<<<<< here
gotGmailFeed(event, data);
else if(strstr(event, "current_weather"))
gotWeather(event, data);
else if (strstr(event, "forecast_weather"))
gotForecast(event, data);
else if (strstr(event, "sun_time"))
gotSunTime(event, data);
I’m subscribing with hooks that contain the Photon’s ID:
I am not sure why you would be getting a 404 from the event endpoint–I thought you could write “sensor/temperature/anything-I-want-up-to-some-length-limit” etc. I cannot seem to get a 404 out of particle subscribe, for instance.
Maybe something else is going wrong with your code in this case–have you tried poking around with a debugger? Or you could try the CLI and particle subscribe or even curl.
