# Ethernet FeatherWing with Xenon - Serial 2
**URL:** https://community.particle.io/t/ethernet-featherwing-with-xenon-serial-2/47678
**Category:** Hardware
**Created:** [February 9, 2019, 9:17pm UTC](https://community.particle.io/t/ethernet-featherwing-with-xenon-serial-2/47678 "2019-02-09T21:17:13Z")
**Posts on this page:** 1
**Showing post:** 3
### Author: ![Jimmie](https://avatars.discourse-cdn.com/v4/letter/j/e95f7d/32.png) [@Jimmie](https://community.particle.io/u/Jimmie)
#### Post date: [February 9, 2019, 9:21pm UTC](https://community.particle.io/t/ethernet-featherwing-with-xenon-serial-2/47678/3 "2019-02-09T21:21:47Z")
Thank you @rickkas7.
Are you saying that using the EthernetWing will prevent the use of Serial2 on the Xenon?
That would be a very serious problem for me since the SoftSerial library does not yet work on mesh devices.
Please see:
> [@Loop() not Executing on Photon with multiple SPI devices](https://community.particle.io/t/loop-not-executing-on-photon-with-multiple-spi-devices/47632):
> I have added the NCD Ethernet shield to a Photon (I realize that it does not permit access to the cloud). I know it is working because the Photon does access my server. However, the loop() routine now is not executing. I read that according to @rickkas7, to prevent this, one needs to put the Photon in Manual Mode. My Photon is in manual mode. I know because it is flashing white and I also cannot reach it through the cloud. I am sure the loop is not executing because my LCD should displ…
_[View the full topic](https://community.particle.io/t/ethernet-featherwing-with-xenon-serial-2/47678)._
