I’m getting errors pertaining to the initialization of arrays. It’s a super simple mistake but I just can’t figure it out. I’m measuring a sensor port and putting that value into the buffer, sleep, and repeat.
error: initializer fails to determine size of ‘data’. and error: call of overloaded ‘println(int [1])’ is ambiguous.
// EXAMPLE USAGE
int sensor1 = A1;
int sensorV = 0;
char sensorStr[64];
int data [10000]; //*
TCPClient client;
byte server[] = { 192,168,2,9 }; // IP address
// Make sure your Serial Terminal app is closed before powering your device
// Now open your Serial Terminal, and hit any key to continue!
pinMode(sensor1, INPUT);
//Particle.variable("sensorV", sensorStr);
while(!Serial.available()) Particle.process();
Serial.println("connecting...");
if (client.connect(server, 6780))
Serial.println("connected");
client.println("HELLO2");
else
Serial.println("connection failed");
// Sleep 1 sec
// byte[] data = sensor.read();
// client.println(data);
int data [] = analogRead(sensor1); //*
delay(2);
if (client.available())
char c = client.read();
Serial.print(c);
//sensorV = analogRead(sensor1);
//snprintf(sensorStr, sizeof(sensorStr), "%d", sensorV);
//client.println(sensorStr);
if (!client.connected())
Serial.println("disconnecting.");
client.stop();
//server_connect();
