Hello, I’m having trouble trying to connect to my Spark to the cloud; I’m getting continuous cyan flashing with the occasional two red flashes (Connection failure due to bad internet connection).
It goes through the normal sequence but fails to breath cyan, although it apparels to be connected to Wi-Fi, as our IT feller can see it on his connection software (Aerohive).
He has opened up Port 5683 on both the Wi-Fi firewall and the main company firewall, but this has not fixed the issue. we don’t have a captive portal.
I guess my question is any ideas? Are there any other ports that we could open?
(Note: Company policy prevents a complete firewall deactivation)
I need to get these connected as we will be placing an order for a few hundred sparks once we get it sorted
A company wide Energy management System/Review, Using ammeters, flow meters, thermometers on key electricity supply lines and heating fluid pipes coming into all campus buildings/floors and departments.
all talking back to the server with Spark Cores
Hmm, we have an AeroHive setup here at Spark HQ actually, so I know it can be done. Maybe try clearing the WiFi profiles on the core in case it’s connecting to an old / wrong AP, and Can you open a connection to the cloud servers ( 54.208.229.4 ) just from a computer on that wifi network? Are you guys able to generate a packet capture of the core during the handshake?
It sounds like it’s connecting, but can you say what security mode / channel you’re connecting on?
I couldn’t get my Spark setup with TI’s smart config on our Cisco Meraki network either (it’s a reasonably common enterprise solution) and the symptoms were similar to yours. However, if I set up the wifi-credentials using serial instead the Spark worked just fine. Maybe that’s something you could try?
@kennethlimcp Yes, I tried using the Spark app, and the TI app, following the instructions in the Spark documentation — but ultimately had to resort to serial.
