End user way to pass variable to firmware?
Has anyone found a good way to pass some variables to your firmware without any “programming” or flashing?
I would like to pass a dozen variables into my program. (Two important ones will be a web address and a 32 char API key), but I am unsure of what the best way might be. Anyone have a bright idea? (Even dim ideas will suffice at this point :stuck_out_tongue: )
A spark function? You can pass pretty long strings that way. Parse the string and save the variable value to eeprom?
Try this:
https://community.spark.io/t/tutorial-spark-variable-and-function-on-one-web-page/4181
Thanks, I have been thinking from an arduino point of view. Times are a changing.
