# Electron - what do I do if no coverage?
**URL:** <https://community.particle.io/t/electron-what-do-i-do-if-no-coverage/20567>\
**Category:** Getting Started\
**Created:** [February 28, 2016, 5:57pm UTC](https://community.particle.io/t/electron-what-do-i-do-if-no-coverage/20567 "2016-02-28T17:57:27Z")\
**Showing post:** 2
**Post date:** [February 28, 2016, 6:07pm UTC](https://community.particle.io/t/electron-what-do-i-do-if-no-coverage/20567/2 "2016-02-28T18:07:59Z")
You still might be in luck. Others have had the same issue and fixed it.
Check out this thread: [Electron G350 connectivity (flash sequence)](https://community.particle.io/t/electron-g350-connectivity-flash-sequence/20216/27?u=rwb)
_[View the full topic](https://community.particle.io/t/electron-what-do-i-do-if-no-coverage/20567)._
