Hi.
We have a number of Electrons in the field and are currently experiencing an issue whereby the cellular connection drops and for some reason doesn’t connected to the tower again. When we send someone to the field we also find that the battery is dead, i.e. it was not charging while trying to reconnect. The device goes from breathing white to flashing green and back to breathing white. I believe this is because there is now insufficient current to make the cellular connection.
If the battery is not charging while trying to reconnect multiple times this could be the cause of the battery been discharged. Does the charging circuitry require the main loop to be processed to charge the battery?
Obviously this doesn’t explain why the electron is not able to reconnect to the tower.
Cheers
Michael
