Hi @apullin I work closely with Soracom and have been able to get everything up and running. Here is a simple app which connects via Soracom Air and publishes events to Particle and also writes data to Soracom Harvest or Funnel (depending on the URL provided). OTA updates also work well, just be sure to set the speed class for your SIM to “s1.fast” before you perform the update (via the Soracom console or APIs). You can then perform an OTA update of your application via the Particle Build console or CLI.
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <HttpClient.h>
#include "application.h"
// Set the soracom APN
STARTUP(cellular_credentials_set("soracom.io", "sora", "sora", NULL));
// Configuration
#define PARTICLE_KEEPALIVE 3000
// device name
#define DEVICE_NAME "ElectronDHT"
// sensor type: [DHT11, DHT22, DHT21, AM2301]
#define DHTTYPE DHT11
// which digital pin for the DHT
#define DHTPIN D3
// which digital pin for the Photon/Spark Core/Electron LED
#define LEDPIN D7
// whether to use Farenheit instead of Celsius
#define USE_FARENHEIT 1
// min/max values (sanity checks)
#define MIN_TEMPERATURE -30
#define MAX_TEMPERATURE 120
#define MIN_HUMIDITY 0
#define MAX_HUMIDITY 100
// sensor sending interval (seconds)
#define SEND_INTERVAL 60
// HTTP POST integration
#define HTTP_POST 1
#define HTTP_POST_HOST "harvest.soracom.io"
#define HTTP_POST_PORT 80
#define HTTP_POST_PATH "/"
// Particle event
#define PARTICLE_EVENT 1
#define PARTICLE_EVENT_NAME "electron-dht-logger-log"
// Integration Includes
#if HTTP_POST
#include "HttpClient/HttpClient.h"
#endif
// Locals
TCPClient tcpClient;
DHT dht(DHTPIN, DHTTYPE);
float humidity;
float temperature;
float heatIndex;
char humidityString[10];
char temperatureString[10];
char heatIndexString[10];
int failed = 0;
// last time since we sent sensor readings
int lastUpdate = 0;
#if HTTP_POST
HttpClient http;
http_header_t httpHeaders[] = {
{ "Content-Type", "application/json" },
{ "Accept" , "*/*"},
{ NULL, NULL }
http_response_t response;
http_request_t request;
#endif
// for HTTP POST and Particle.publish payloads
char payload[1024];
* Setup
pinMode(LEDPIN, OUTPUT);
digitalWrite(LEDPIN, HIGH);
// configure Particle variables - float isn't accepted, so we have to use string versions
Particle.variable("temperature", &temperatureString[0], STRING);
Particle.variable("humidity", &humidityString[0], STRING);
Particle.variable("heatIndex", &heatIndexString[0], STRING);
Particle.variable("status", &failed, INT);
// start the DHT sensor
dht.begin();
#if PARTICLE_EVENT
// startup event
sprintf(payload,
"{\"device\":\"%s\",\"state\":\"starting\"}",
DEVICE_NAME);
Spark.publish(PARTICLE_EVENT_NAME, payload, 60, PRIVATE);
#endif
// run the first measurement
loop();
* Event loop
int now = Time.now();
// only run every SEND_INTERVAL seconds
if (now - lastUpdate < SEND_INTERVAL) {
return;
// turn on LED when updating
lastUpdate = now;
failed = 0;
// read humidity and temperature values
humidity = dht.readHumidity();
temperature = dht.readTemperature(USE_FARENHEIT);
if (temperature == NAN
|| humidity == NAN
|| temperature > MAX_TEMPERATURE
|| temperature < MIN_TEMPERATURE
|| humidity > MAX_HUMIDITY
|| humidity < MIN_HUMIDITY) {
// if any sensor failed, bail on updates
failed = 1;
} else {
failed = 0;
// calculate the heat index
heatIndex = dht.computeHeatIndex(temperature, humidity, USE_FARENHEIT);
// convert floats to strings for Particle variables
sprintf(temperatureString, "%.2f", temperature);
sprintf(humidityString, "%.2f", humidity);
sprintf(heatIndexString, "%.2f", heatIndex);
sprintf(payload,
"{\"device\":\"%s\",\"temperature\":%.2f,\"humidity\":%.2f,\"heatIndex\":%.2f}",
DEVICE_NAME,
temperature,
humidity,
heatIndex);
#if HTTP_POST
request.hostname = HTTP_POST_HOST;
request.port = HTTP_POST_PORT;
request.path = HTTP_POST_PATH;
request.body = payload;
http.post(request, response, httpHeaders);
#endif
// done updating
digitalWrite(LEDPIN, LOW);
