Electron function with no connection
Hello,
I am working on designing a controller for a mobile application using the Electron. The controller needs will be mounted on a vehicle and used to control various devices, but i would also like it to send data periodically to ThingSpeak. I was wondering if the Electron will still function normally if it loses cellular connection. I don’t want my controller to stop functioning if it needs to reconnect to the cloud for some reason.
Thanks for the help.
First, yes that is possible.
And next, if you have a look at the docs under SYSTEM_MODE and SYSTEM_THREAD you will find some info how to do this.
