Is anyone else seeing their Electrons cycle? My previous OK electron is now flashing green as of this morning, not connecting, then it looks like the watchdog is kicking in and restarting it.
Is anyone currently experiencing this on a previously OK Electron?
Matthew
Did you check if the data usage is over the limits?
Yes I did. It all looks fine. Just in case, I raised the limit again up to 10MB. Here’s the profile:
You can see that it has plateaued.
Matthew
Upgraded the firmware to 0.6.3. It now successfully comes online.
Well, after a day or so it now is reverting back to its old behaviour. I’ve not pushed any new code. The only difference was that I refreshed the firmware using a particle update cli command.
Any ideas?
