Electron Breadboard Template
Anyone else noticed that the template that comes with the electron, that shows how to wire up and LED and LDR is not quite right?
The LED is aligned correctly, but if you follow the diagram, you’d end up wiring the LDR to A4 instead of A5 and B5 instead of A0, but the GND connection is aligned.
So beware newbies… you need to follow the labels on the electron, don’t blindly follow the cardboard template.
Yup, that was already noted, but thanks for the heads up!
