Hi all,
For the second time the connector in my electron broke apart.
To prevent this from happening… I plan to sodder the antenna cable directly on the board.
Any suggestions on where the external ground wire goes and where does the internal goes?
If I check continuity on the board all three pins of the antenna connector (board side) have continuity!!
