Hi, I have created 2 Indexes in ElasticSearch which i can see and configure using ElasticSearch head plugin.
1 index is created using the app which is integrated with ES and other one i created manually using Bulk API. I want to integrate it in Freeboard using json datasource and create Gauge report out of it.
After creating json datasource on the home page its showing Last updated ‘never’ and i think its not understanding the endpoint i have given.
This is the URL i am giving in freeboard as json URL.
Try thingproxy - yes
Refresh every 100 sec
Method - GET
Body - blank
header -hostname - localhost
Please suggest what is going wrong and what is the correct Elasticsearch URL i should use.
