Hi
has anyone used this library to connect to other 1-wire devices apart from temperature sensors.
I am trying to communicate with DS2423 and DS2438.
Hi
There’s no reason why it should not work. The low-level primitives to access the chips are the same across all 1-Wire devices, and those are exposed in DS2482-RK.
However, it’s not exactly trivial to add new devices because the library is completely asynchronous and this makes it easy and efficient to use, but a pain to add new devices to.
There is some DS2438 code here:
May be useful as reference. I would like to move to the DS2482-RK model at some point in the future …
Hi
Thanks for that - I have got the ds1820 and ds2423 basically working using your libraries low level commands so looking good.
Hi
I have code for ds2438 in another environment so just need to port it.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
