Don't want URL encoding of & and = for webhook
I’m trying to use a Product webhook that takes a single pre-formatted GET string. I don’t want to have to define each possible parameter in the webhook itself.
Product webhook: GET, Query parameters:
“X-API-KEY”: “{{key}}”
Sending to requestb.in for debugging. GET string I want to see generated by the webhook.
GET /17yew01?X-API-KEY=9d55ca639a860237&address=STE1704002&limit=10
Instead I receive:
GET /17yew01?X-API-KEY=9d55ca639a860237%26amp%3Baddress%3DSTE1704002%26amp%3Blimit%3D10
I read that triple curly braces should prevent encoding. I tried:
“X-API-KEY”: “{{{key}}}”
And I get:
GET /17yew01?X-API-KEY=9d55ca639a860237%26address%3DSTE1704002%26limit%3D10
My Electron code:
String output = "{\"key\":\"" + DeviceKey;
output.concat("&address=" + DeviceID);
output.concat("&limit=10");
output.concat("\"}");
success = Particle.publish("commands", output, NO_ACK, PRIVATE);
Any idea how I can prevent the & and = from getting encoded?
I think you’ll have to
