Does the B-Series have an Enable pin?
Does the B-Series have an Enable (EN) pin like the normal boron does?
I can’t seem to find it on the pinout or pin description on the datasheet…
EDIT: The B-Series does not come with the XC8107 chip, so looks like it doesn’t have an Enable pin.
Since the EN pin on the Feather devices turns off the power block (required for Feathers) and the B-Series comes without its own power block but relies on the carrier bord to provide the power it’s up to the carrier designer to facitlitate such an option when needed.
ScruffR is correct. However the evaluation board schematic shows how you could create one using a load switch (XC8107) with the B402.
38%20AM
