I have a few of photons running temp sensors. I am trying to use a pi running the particle-agent to run the same system. On the photons System.deviceID() gives me the 24 digit device ID. Running the exact same code on the pi gives me a bunch of zeros as the deviceID.
Am I missing something or is that not available on the Pi?
String deviceId = System.deviceID();
//In Setup
Particle.variable("devId", deviceId);
Then in the console is shows:
Any help would be appreciated. If you need more info just ask. Thanks
