Does entersafemode work?
Does entersafemode work ? , because in my code it just resets and go back to normal running.
I posted things to my server and received a reply , if I received the right reply it did a entersafemode .
@peter_a you need to give more context and the code you used to do that…
O.K , I want it to come up of deepsleep into safemode is I can write new code to it, but instead of going to safemode it just resets.
Something like this? (This example is not working yet)
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
retained int safeMode = 0;
void setup(){
  if(safeMode == 1)
      System.enterSafeMode();
void loop(){
   safeMode = 1;
   System.sleep(SLEEP_MODE_DEEP);
I am also not being successful with enterSafe mode function call on my application.
This does not work:
void loop(){
  if (enterSafeMode=true) {
    enterSafeMode=false;
enterSafeMode VAR is set with a button on interrupt…
When this is pressed in resets and starts again instead of entering safeMode. I know the interrupt and the button works, because if i change the system.enterSafeMode to deepSleep… and it does work. Or to light an LED.
This issue is now officially filed
https://github.com/spark/firmware/issues/751
Looks like this issue was just closed. Is there an estimated release date for 0.4.9?
Estimated end this week
Which week ?
Monday 25th January
The week when the statement was written, which was this week, still :wink:
OK, due to some minor delays it’s actually after this, beginning next week.
For future reference, if you look top right of each post you’ll see when it was posted - this should help to know how to interpret such statements :sunglasses:
