i want to build an web site by djnago. this site could be able to take values from Temperature sensor which is connection with my particle-Photon. i checked the net but i do not found an compatible libary Which could be connect my Photon and django framwork. is there any helpful libary to do this. like on php there is " stej/php-particle "
I’m not a Python developer so I can’t help with a Django library. One thing you could consider is using Particle’s webhook feature to POST values to your Django app.
thank you…
i think i will use Django REST framwork. it must be helpful
It’s a good way to get started. Then you could write your own Python library and share it with everyone
