Hey Guys,
I am using the D7 pin in the argon for SPI communication. Is there a way to disable the LED in the D7 pin?
Thanks & regards,
Rahul G
Hey Guys,
Thanks & regards,
Rahul G
@Rahul_G, a LED (LED1) and a current limiting resistor (R3) are hardwired to D7 so you can’t disable it without removing a component. Removing either component will be tricky given their size.
Thanks @peekay123 for the info.
