# Digole UART/I2C/SPI Display Library
**URL:** <https://community.particle.io/t/digole-uart-i2c-spi-display-library/2392>\
**Category:** Libraries\
**Created:** [January 26, 2014, 8:01am UTC](https://community.particle.io/t/digole-uart-i2c-spi-display-library/2392 "2014-01-26T08:01:44Z")\
**Showing post:** 345
**Post date:** [March 10, 2014, 5:10pm UTC](https://community.particle.io/t/digole-uart-i2c-spi-display-library/2392/345 "2014-03-10T17:10:19Z")
> [@peekay123](#):
> const uint8\_t startscreen{1024] = { ... EXACTLY 1024 bytes of screen data here ...};
@peekay123 Ok I have tried to upload the start screen a million times now and get garbled results every time.
Here is the image code from the online Digole conversion software. All my other images show up just fine when created and called from the main loop. See if you can get this image uploaded to your screen successfully.
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x03,0xe0,0x80,0x00,0x03,0x80,0x00,0x02,0x00,0x02,0x00,0x38,0x00,0x00,0x00,0x20
,0x02,0xa0,0x80,0x00,0x02,0x80,0x00,0x02,0x00,0x02,0x00,0x28,0x00,0x00,0x00,0x20
,0x00,0x80,0xe0,0xe0,0x02,0x83,0x83,0x82,0x83,0x83,0x00,0x28,0x38,0x38,0x38,0x20
,0x00,0x80,0xa0,0xa0,0x02,0x82,0x82,0x82,0x82,0x82,0x00,0x28,0x28,0x28,0x28,0x20
,0x00,0x80,0xa0,0xa0,0x03,0x82,0x82,0x03,0x02,0x82,0x00,0x38,0x08,0x28,0x28,0x20
,0x00,0x80,0xa0,0xe0,0x02,0x02,0x82,0x03,0x03,0x82,0x00,0x20,0x38,0x28,0x38,0x20
,0x00,0x80,0xa0,0x80,0x02,0x02,0x82,0x03,0x02,0x02,0x00,0x20,0x28,0x28,0x20,0x20
,0x00,0x80,0xa0,0xa0,0x02,0x02,0x82,0x82,0x82,0x82,0x00,0x20,0x28,0x28,0x28,0x20
,0x00,0x80,0xa0,0xe0,0x02,0x03,0x83,0x82,0x83,0x83,0x00,0x20,0x38,0x28,0x38,0x20
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x80,0x00,0x40,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x07,0xf0,0x02,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x3f,0xfe,0x04,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0xff,0xff,0x88,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xfb,0xff,0xc0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xbf,0xee,0xe0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xff,0xff,0xf0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0xff,0x7d,0xf8,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0xfb,0xff,0xd8,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x1d,0xff,0xfb,0xfc,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0xff,0x7f,0xfc,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xbf,0xef,0xfe,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x3d,0xff,0xff,0xbe,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xff,0xff,0xfe,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x1f,0xbf,0xfd,0xbf,0xfe,0xfc,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x2f,0xbf,0xfb,0xb6,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0xff,0x7f,0xfe,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x3d,0xf7,0xff,0xfe,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0xff,0xff,0xdc,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0xff,0xdf,0xfc,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0xdf,0xfd,0xf8,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x0f,0xfe,0xff,0xf8,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xff,0xdf,0xf0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xf7,0xfb,0xe0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xff,0xff,0xc0,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x3e,0xfe,0x04,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x04,0x00,0x00,0x44,0x00,0x00,0x70,0x02,0x40,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x04,0x00,0x00,0x44,0x00,0x00,0x50,0x04,0x40,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x04,0x00,0x00,0x40,0x00,0x00,0x50,0x04,0x40,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x04,0x1c,0x71,0xc4,0x71,0xc0,0x41,0xc6,0x65,0x47,0x1c,0x70,0x00,0x00
,0x00,0x00,0x04,0x14,0x51,0x44,0x51,0x40,0x21,0x44,0x45,0x45,0x14,0x50,0x00,0x00
,0x00,0x00,0x04,0x14,0x11,0x44,0x51,0x40,0x21,0x44,0x45,0x41,0x10,0x50,0x00,0x00
,0x00,0x00,0x04,0x14,0x71,0x44,0x51,0x40,0x11,0x44,0x45,0x47,0x10,0x70,0x00,0x00
,0x00,0x00,0x05,0x14,0x51,0x44,0x51,0x40,0x51,0x44,0x45,0x45,0x10,0x40,0x00,0x00
,0x00,0x00,0x05,0x14,0x51,0x44,0x51,0x40,0x51,0x44,0x42,0x85,0x10,0x50,0x00,0x00
,0x00,0x00,0x07,0x1c,0x71,0xc4,0x51,0xc0,0x71,0xc4,0x62,0x87,0x10,0x70,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xc0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
_[View the full topic](https://community.particle.io/t/digole-uart-i2c-spi-display-library/2392)._
