I created a function which apply weighted moving average and Loglikehood ratio test and Binary Integration to process my XBand Radar signal.
I flashed and ran this function on particle Photon with wifi on and using micro() function to get time before and after execute this function. The result I got is ~12600 microseconds. I know many ppl have better way to optimize this code, so here it is. thanks for all your help.
int Detection::Detector(volatile float *XBsignal,volatile float *PIRsignal, int lenXBsignal, int lenPIRsignal, float noise_Var, float Vt, float signal_Var,int Fs,float meanXBVal,int *PIRsum)
int Fo = 100; //default for stage 2, 10 observation
int Fo1 = 10; // default stage 1, 10 observation
int *stage1Detection = NULL;
stage1Detection = (int*) malloc(Fo*sizeof(int));
int window = 7; //moving average window, using Matlab to calculate window
float *binomialCoeff = NULL;
int lenbinomialCoeff;
float h[2] = {0.5,0.5};
binomialCoeff = (float*) malloc(window*sizeof(float));
conv(h,h,2,2,binomialCoeff,&lenbinomialCoeff);
for (int n = 1;n<=window-3;n++)
conv(binomialCoeff,h,lenbinomialCoeff,2,binomialCoeff,&lenbinomialCoeff);
float lrt =(2*pow(noise_Var,2)*pow(signal_Var,2)/(pow(signal_Var,2) - pow(noise_Var,2)))*log(Vt) - (Fs/Fo)*log(noise_Var/signal_Var);
// Detection::SetValues(XBsignal, lenXBsignal);
mean = meanXBVal;
// XFiltered = (float*) malloc(Fs*sizeof(float));
// Detection::WMA(XBsignal,XFiltered,lenXBsignal,7);
// do not need mean value anymore free memory
//120 usecond up to here
int sumXB = 0;
int sumPIR = 0;
int stage2Observation = 0;
int sumXBandstage2 = 0;
int sumPIRstage2 = 0;
int k;
for (int observation = 0;observation < Fo; observation++)
float sumxobssq = 0;
// calculate weighted moving average for each element
for (int i = 0; i < Fs/Fo; i++)
float WMA_k = 0;
k = i + (Fs/Fo)*observation;
if (k < window - int(window/2))
for (int n = (window/2)-i;n < window;n++)
WMA_k = WMA_k+binomialCoeff[n]*(XBsignal[n-window/2 + k]-mean);
// wsignal[k] = WMA_k; //should be devide by sum of weight, but sum of weight = 1 in this case
else if (k < Fs - int(round(window/2)))
for (int n = 0;n<window;n++)
WMA_k = WMA_k+binomialCoeff[n]*(XBsignal[n+k-int(window/2)]-mean);
else
WMA_k = XBsignal[k] - mean;
//end weighted moving average
sumxobssq = sumxobssq + pow(WMA_k,2); // calculate N*R^2 for log likelihood ratio test
if (sumxobssq > lrt)
sumXB = sumXB + 1;
sumPIR = sumPIR + PIRsignal[observation];
stage2Observation++;
if (stage2Observation == Fo1)
if (sumXB > 7)
sumXBandstage2 = sumXBandstage2 + 1;
if (sumPIR > 7)
sumPIRstage2 = sumPIRstage2 + 1;
sumPIR = 0;
sumXB = 0;
(*PIRsum) = sumPIRstage2;
free(stage1Detection);
// free(XFiltered);
// XFiltered = NULL;
return (sumPIRstage2 + sumXBandstage2);
