I’m quite puzzled with my setup. I have a few Photons which have several DHT11’s connected to them, originally connected to D4 & D5 and displaying without issues.
I have recently needed to utilize D0 through D7 so I have coded the existing Pins to Analog ‘A4’ & ‘A5’ for the DHT11(s).
Analog ‘A4’ displays the Temperature/Humidity just fine but I get no readings from Analog ‘A5’? I have tried different sensors but am not getting anything to display using ‘A5’, what gives?
I continue to struggle to understand why only ‘A4’ works and why ‘A5’ does not, I have even tested ‘A0’ and still cannot get a reading.
I spent endless nights the past week trying all combinations of hardware and code and simply cannot figure out why it won’t display.
Which library are you using?
If the library uses interrupts to read the data stream you need to use pins that do support interrupts. On the photon the pins D0 and A5 do not
For example the PietteTech_DHT library even states the need for interrupt enabled pins in the leading comment
// With this library connect the DHT sensor to the interrupt enabled pins
// See docs for more background
// https://docs.particle.io/reference/firmware/photon/#attachinterrupt-
