Device OS Compatibility with Monitor One Monitor-Edge
I am getting Stack Overflow using Device OS 6.3.4 on a Monitore One using monitor-edge firmware. Do I need to go back on Device OS versions? I'm wondering if I've got the wrong Device OS for monitor-edge.
If it wouldn't be too difficult, could you test with Device OS 6.4.0? There was a fix for the stack size of the IO Expander Thread in Device OS. This code is used on the Monitor One (and Tracker One). I don't recall this being an issue users had reported, but it did show up in stress testing that the stack size was too small, causing an intermittent SOS+13.
I will do that and reply back. I would say that my SOS+13 was intermittent. Sometimes 30 seconds sometimes >1hr to trigger it.
I upgraded to Device OS 6.4.0 and it appears the issue has gone away. Thank you.
