Dev error: form-data: ENOENT no such file or directory [SOLVED]
If it helps someone else, in Particle Dev I couldn’t flash my firmware receiving the error: form-data: ENOENT no such file or directory
I could see the new bin files created in the directory so it made no sense. Once I deleted the files (I created ones for both 0.6.2 and 0.6.3) and compiled it again I was able to flash.
