I have a need to detect and display if the Photon is in listening mode on powerup / reset. These Photons are mounted in an electrical box where the flashing blue LED cannot be seen. I have an OLED display connected to the Photon and would like to display “Listening” in this situation. These Photons, (8 so far) operate in “Automatic” mode and I would like to keep it that way if possible. I guess what I am asking for is a way to run my code in listening mode. The code I am currently using is…
#include "application.h"
#include "WebServer.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 5
#define SSD1306_96_16
Adafruit_SSD1306 display(OLED_RESET);
int listeningMode = 0;
if (digitalRead(6) == LOW ) { ListeningMode(); } // manually put the Photon is listening mode
if (! listeningMode) { // run the loop code as normal
if (! Particle.connected()) { Particle.connect(); } // If connection is lost re-establish it
webserver.processConnection(); // Process web requests
// ------------------- Time / Temperature Inside and Out --------------------
display.clearDisplay();
void ListeningMode() {
listeningMode = 1; // disable the void loop from doing anything, i.e. clear the OLED display
display.clearDisplay(); display.setCursor(10,0); display.setTextSize(2); display.print("Listening");
display.setCursor(0,24); display.setTextSize(1);
display.print(EEPROM.get(26, tempname)); // display the last known "hardware name" of the Photon
display.display();
WiFi.clearCredentials(); // delete all the old WiFi credentials
WiFi.listen(); // put the Photon in listening mode
(ScruffR: Did the reformatting)
I know there is some redundancy in the above code however, this same code is used to put the Photon in Listening Mode when a button is pressed on boot-up. The key to this is the OLED displays “Listening” to identify the Photon is in Listening Mode. The code works as I want on a power-up / reset IF there are Credentials currently in the Photon.
The problem is, if the Photon is reset a second time or a power cycle occurs, the Photon does not run the setup / loop code. Therefore the OLED display is blank and the user cannot tell the Photon is in listening mode.
Any Suggestions?
Sorry not sure why the include/ defines and are in large bold font. (on my screen they were normal size)
