I’m getting started using the desktop IDE and I’m having a bit of difficulty switching between projects.
When i compile and load one project, and then switch to a different project and hit compile, it compiles and loads the project i previously had open.
is there a place where i can see and change which project is “active” to be compiled and loaded?
it also seems to keep recompiling the same code and not reloading after i save changes. closing and reopening the IDE clears this.
