# Desktop Dev - Error message on Loading
**URL:** <https://community.particle.io/t/desktop-dev-error-message-on-loading/45639>\
**Created:** [November 27, 2018, 4:52pm UTC](https://community.particle.io/t/desktop-dev-error-message-on-loading/45639 "2018-11-27T16:52:42Z")\
**Showing post:** 2
**Author:** ![Postler](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/postler/32/13693_2.png) [@Postler](https://community.particle.io/u/Postler)\
**Post date:** [December 1, 2018, 11:27pm UTC](https://community.particle.io/t/desktop-dev-error-message-on-loading/45639/2 "2018-12-01T23:27:18Z")
Have an eye to this thread in the past, @stovalldb
> [@ParticleDevSetup.exe: Installation has failed](https://community.particle.io/t/particledevsetup-exe-installation-has-failed/22349):
> Particle Dev Setup giving this error… Tried on 2 different PC’s and getting the same error! Also refer to the attached SquirrelSetup Log [image] SquirrelSetup Log:- 2016-04-23 12:21:30\> Program: Starting Squirrel Updater: --install . 2016-04-23 12:21:30\> Program: Starting install, writing to C:\Users\Ragava\AppData\Local\SquirrelTemp 2016-04-23 12:21:30\> Program: About to install to: C:\Users\Ragava\AppData\Local\particle 2016-04-23 12:21:30\> CheckForUpdateImpl: Failed to load local releases,…
_[View the full topic](https://community.particle.io/t/desktop-dev-error-message-on-loading/45639)._
