Deep update, not asked to do it when i log into ide
Im not asked to do the update? Any idea why?
Hi @kiwibird1 - do you have black Cores? If your Cores are black, that means that they came from the most recent manufacturing run, and they do not require the update. If your Cores are white, then they require the update, although if you have applied a CC3000 patch yourself then they might be flagged as already up to date.
