Debug logging, serial output truncated
I’ve noticed in my Log handler, when I try to output a long string, it gets truncated and appended with a tilde (~) character. It outputs about 160 characters and truncates the rest. Is this expected?
Hi @picsil - I can confirm that SerialLogHandler uses a buffer that can hold <=160 characters. I believe this is a fixed limit.
Ah, an update! There is a bit of a workaround here, so long as you have access to the log (you can’t affect system logs this way).
Try: LOG_PRINT or LOG_DUMP. You can find more information about this here: https://github.com/particle-iot/device-os/blob/develop/services/inc/logging.h
Thank you for the confirmation, and the alternatives.
